2015 Patriot Front Strut Trouble
278 views 5 replies 5 participants last post by  Treegrower
Since December I have been rebuilding the front suspension, to include wheel bearing hubs, lower control arms, steering links, roll bar bushings, links and struts. With over 350k miles everything was knocking and rattling. My issue now is finding new "Quick Struts" that fit correctly. Lower Control Arms have been change twice now because the first ones were crap. Detroit Axle sent me struts for a 4x4, which I wrongfully installed. They refunded those and sent a 2nd set. These second struts (that are supposed to be the right ones) are rubbing on the inside of the fender! The coil springs are rubbing on the inside of the fenders . . . AND . . . the bottom of the strut curves downward and touches the CV Axle Boot. Luckily the boots have not been torn yet. So now I have SO LITTLE CONFIDENCE in aftermarket parts I don't know what to trust. A lot of STRUTS don't come with the coil spring . . . and so I'm now wondering, "How can I trust the COIL SPRING I'm getting for the right ride height and tension." (Suspension action.) I don't want heavy duty or anything else other than the original height and spring compression. So I have two questions:
1. After 377K miles would you re-use the original springs? (I feel like the car rolls a little more than it should. A little more stiffness would be ok, but just a little. I don't want a hard ride.)
2. Has anyone had success with a reasonably priced brand of strut or quick strut? I would prefer to buy the whole assembly and not have to change springs. I will be installing the 3rd set of struts.
A mechanic told me to quit buying parts on-line. He said it's all crap.
A local 4x4 shop can get Billstein struts for about $128. each, but I have to put the springs on. Then the question arises, do I use the 377k mile springs?
James Gingles, A&P
I haven't used quick struts, but if I were in your situation I'd consider KYB SR4467 and SR4468, Rock Auto carries them.
One member here used the KYB 4x4 quick struts with good results:
Another alternative would be getting a set of struts/springs from a low mileage vehicle at a salvage yard.
As far as equipment online all being crap, that’s not true. Because plenty of quality parts for the Jeep Patriot and Compass are available online. The key with suspension parts is: don’t buy the cheapest thing on Amazon/Rock Auto, because they do tend to be not as good quality. KYB seems to be a decent brand that I’ve heard a lot of people use on their Patriots. But you also have companies like Billstein, Monroe, etc that make quality parts too.
The truth is, there’s plenty of auto parts that the parts stores get that are crap too. This is why I research the parts I buy extensively before buying them. Some things, cheap parts are okay with. I spent like $45 on my spark coils set from Amazon and they’ve been fabulous, driven with them to other states. Way cheaper than OEM or parts store coils.
But suspension parts take a lot of physical stress, so they need to be better made to last longer.
Springs don't lose sprint rates, but can lose height. So if it's a 350 lb per inch spring rate it will still have that rate even if it loses an inch of height. Not sure if that helps with your decision or not but the more you know...
Wanted to let everyone know that I wound up spending extra $$ and going with KYB! Man they're beautiful! Quiet, smooth and you can feel the suspension working. The car rides like showroom again. STAY AWAY FROM Detroit Axle. They're crap junk and I put in two pair in front. 1st they sent me wrong struts for a 4X4. Then they sent what they say are the right ones but the coils rubbed on the inside of my fender wells and the bottom of the struts literally tore open the CV Axle boots. That was all in June. I'm still trying to get the $138.52 refund that Detroit Axle said I would get. Still haven't got it. They've also sent me 3 fuel pumps now. They run loud as hell. When my wife goes to the store I can hear their fuel pump in the house. I'm done with Detroit Axle. Their wheel bearings are also junk. Hit a pot hole or curb and your wheel is loose again.
Thanks for the review of the KYB quick struts. Please keep us posted on how they perform going forward.
The auto forum(s) I participate in all agree that aftermarket parts are really hit or miss nowadays. Even name brands like MOOG, Timken, etc. are developing iffy reputations. Just my opinion.
