Hi All,
Recently I noticed my front end was sagging quite a bit and last week I heard a humming/rubbing sound from my front driver side tire. Upon inspection with the tire removed I found the strut was leaking plus the top of the coil rusted off the top mount. The whole assembly was sitting on my tire! So I couldn't use the coils again in this situation and got the KYB Strut Plus SR4507 and SR4508 for the front end, complete strut assembly with coils.
For the removal of the old struts it was fairly straight-forward, I did one side at a time.
Install is the reversal but here are some tips:
Torque Specs are different between older and newer patriots and for KYB struts so make yourself aware.
I compared the old struts afterwards and found them to be 2 different struts installed, the Passenger side was definitely OEM jeep, still had stickers with part numbers and in pretty good condition. Whereas the failed driver side was actually 1/2 inch shorter and had a different bellow and looked much older hence the coil and bearings rusted away. A previous owner must have fixed it up using scrapyard parts from a older Patriot/compass/something that seemed to work for a time.
KYB has a note tagged on the struts stating these will ride higher and need to settle. That is very true, I almost consider it a very very modest leveling lift perhaps 1/2 inch or 1 inch MAYBE. unfortunately I didn't measure before since my struts failed and was messed up on both sides, because of this I didn't bother. But this new gained height should go down a bit over time. I now have to consider adjusting my lights to point downwards a bit too. Current height from ground to fender is 31 7/8" on the driver side.
The ride quality is good. A tad stiffer in a good way, a bit more responsive and gave my Patriot a crisp feeling like a new car again. I'm quite happy so far. Maybe in 6 month these will have settled down and I give a follow-up again. If I don't please just ask me!
- Jack up the car and place a jack stand under the frame and remove the tire. I used a floor jack (or you can use the factory scissor jack in the trunk too) to lift the knuckle up a bit to remove the Sway link from the strut.
- Open the hood and remove the 3 15mm strut nuts except for one, leave it one by a few threads to so it doesn't fall out later on you.
- Remove the 13mm bolt holding the brake lines (just the lower bolt needs to be removed). Remove the 21mm nuts holding the struts to the knuckle, do not turn the serrated bolts and you can hold them in place with a wrench in case they rotate. Thread a nut on the bolts a bit to protect the treads as you have to knock these out with a hammer.
- Lower the jack under the knuckle and the strut should separate. Reach on top and undo that 15mm nut holding it and carefully pull the strut unit out.
- The 3 Strut nuts are 14mm from KYB.
- Use the jack to lift the knuckle back into the strut.
- Torque the 3 nuts on top once the wheels are back on.
