Hello I hope this helps you. I just brought my Patriot back from the shop last week and we solved the stalling problem. When driving at slow speeds in town, the car would stall and I would have to Coast over to the curb. Then it might not start again for anywhere from 5 minutes to 30 minutes. The engine would crank over fine, but it just wouldn't start. Unless I let it sit for a while.
The cause was a sensor called the crankshaft position indicator. I was sometimes getting this code as a Check Engine Light on the instrument panel. The mechanic changed out that sensor, and he also replaced the transmission fluid. You will have to change fluids at 120,000 miles anyway.
So replacing the crankshaft position indicator, which is part of the transmission, was $46. Replacing the fluid plus labor will probably get you a bill around $300-350. Still cheaper than buying a new car. Good luck and let me know how it goes. Mark.
