Hi, welcome to the forums, glad to hear you're having a good run of it so far!
A couple things to watch are sub-frame rust, and throttle bodies have been an issue for some.
Factory style spark plugs need replaced at around 30k or it can cause stutter and hesitation.
I'm not sure which transmission you have, but if you have the CVT I recommend the factory fluid and both filters changed at 30k then 30-50k thereafter. It's not too difficult to do, several here have done it ourselves and we're not all professional mechanics. Dealers can charge $400 - up for a drain and refill (you don't need a machine flush), independent shops can be less but make sure they know what they're doing.
More info on fluid and filter changes here:
Been done to death but I cant find all info with links etc to know i'm on right track. Want to service the CVT (replace filters and fluid) also have seen this 4 ports CVT Transmission Oil Cooler, 2 for Engine Coolant 2 for CVT Fluid. 2 pipes for the inlet/outlet of coolant 2 pipes for the...
www.jeeppatriot.com
