Rocky Road, Rough Country, and Daystar all sell pretty much the same thing, except with Rocky Road you get an extra 1/8". All of them will stress out your axles and suspension angles quite a bit for that little bit of lift.
Murchison STU coils like
@Sandstone has, while they give only 1" less lift if you're running the FD2-height suspension(standard on post-2010 FD1 models, but not pre-2011 FD1), will not cause as sharp of angles but will stiffen the ride a bit.
So if you like how the Patriot rides a bit more like a sedan than a pickup truck on the road but don't wanna shell out $$$$$$ pioneering a new lift that extends the suspension and axles further from the vehicle to give decent lift without stressing all those angles, honestly my advice is to just leave the suspension as it is and get some BFGoodrich Trail-Terrain tires in a size you know will work. I'm planning on getting some 215/65R17's if, Lord willing, I get the opportunity to do so. It's not the biggest I can run, but it's the factory size for mine so there's no need to have the gauges recalibrated and that size has already worked well for me for the better part of 15 years now.
