How long did your OEM brakes last?
16K views 31 replies 15 participants last post by  croat
Wondering how long the OEM brakes on everyone's Patriot lasted?
My 2012 Limited has 80,000 km (50,000 miles) and dealer is recommending replacing them. They also advised me to replace them at my last oil change, now they are saying my pads have 3mm left and recommend replacing the rotors at the same time.
So how long did your OEM brakes last?
Also, please note if you've had any preventative service or maintenance along the way.
On our 2008 Patriot I got about 160 k km on the OEM brakes. I then got aftermarket pads and rotors from a trusted mechanic but they only lasted about 30 k km when the replacement rotors got warped and the brake pedal was pulsating. We traded our 2008 Patriot in after the 2nd replacement of pads and rotors. When the brakes wear out on our 2015 Patriot I'm gonna get factory parts. I still don't know what is better ceramic or steel.
160k is amazing, that's twice lifespan of what I'm getting from mine and I've intentionally gone easy them. Did you do any preventative maintenance? Or ever have someone recommend changing them earlier? Maybe living in an area that uses less road salt than Toronto does in the winter? What's the secret?
120,000 and still on original brakes!
My rear brakes went first at about 90,000 miles. Fronts went quite a bit longer -- maybe closer to 120,000 miles. That surprised me in two ways: 1) That the front brakes outlasted the rear brakes, and 2) that either set ever lasted so long. I've never had brakes on anything last that long.
What's even more amazing is I'm still on the replacement set. I'm now at 209,000 miles so those rears have gone almost 120,000 miles.
I'll admit my driving style is pretty easy. I like to get my mpg up there, so I anticipate my stops and use the transmission to hold down my speed on hills.
Here is my math:
- My brake pads are currently at 3mm, and new pads are 12mm.
- So over 52 months I've used 9mm, which is 0.173mm per month.
- Using 0.173mm per month with 3mm remaining gives me 17 months.
- I've driven 80,000 km in those 52 months, which is 1538 km per month.
- 17 months at 1538 km per month is 26,146 km.
- So that's 106,146 km until my brakes are gone.
If the brakes feel normal, and there is no vibration or pulsing, and they are not making any noise, is it ok to keep driving until these warning signs start to show themselves?
Personally I think there are far too many variables to consider the maths when trying to calculate how much time / how many Kms you have until you need to replace your pads.
If the brakes feel normal, no pulsing or vibrations etc then yes, you should be right to drive on them. Only issue you have is risk warping the rotor, but usually you see the signs to replace them by then.
54,000 and still going strong. It looks like I still have a decent amount of time left on these originals.
When most rotors cost brand new less than the labor for turning them its no wonder that turning has been eliminated from the auto industry.
Remember that in most every drivers case, the cheaper quality/priced ones are just fine for their daily driven application. If you are putting your brakes through rough conditions, the upgrade makes sense however in the end I cannot think of any reason any application is in need of turning rotors any more.
