Finally completed my Stereo System!
1.8K views 14 replies 5 participants last post by  blainehowerton90
Hey everyone, my stereo in my 2015 Jeep Compass is finally complete. If you have a Patriot, this setup would be the same for yoyI wanted to share this with you all and let you know the individual components that I used. Here’s a list with links.
Head Unit: TopWeb 10.1” Android unit Amazon.com
Speakers: Alpine SPS-609 6x9” Speakers https://a.co/d/2yQNmsW
Amplifier: Alpine Powerpack KTP-445u https://a.co/d/aCkvmxM
Powered Sub: Rockford Fosgate P300-12 https://a.co/d/01apH3g
Line Driver: Audio Control LC1i https://a.co/d/cNW8xxQ
USB Panel-mount Extension: https://a.co/d/7PGI05d
AUX-in Panel-mount Extension: https://a.co/d/85OFPsG
USB Fan: https://a.co/d/2bl2HEr
Speaker Harnesses: https://a.co/d/65HmtnO
Camera Bracket: https://a.co/d/bOs57ay
Amp Wiring Kit: https://a.co/d/bs5uXvu
I’ve been very happy with this system. The head unit has been very reliable and also has a lot of modern features.The TopWeb unit comes with everything you need to install it, all wiring, Gps antenna, the backup camera, etc. It works with the steering wheel controls out of the box. The head unit also has a CanBus box which makes the following features possible: dynamic backup lines that move with the steering wheel, speed displayed on Home Screen, an on-screen icon that alerts you which doors are open, and some more Compass/Patriot specific stuff. Of all the Android head unit available for the Compass or Patriot, I believe this one is the best. I added panel mount extensions in the center console for the USB and Aux inputs. I also added a license plate bracket for the backup camera.
The Alpine 6x9’s in the doors sound great. The powerpack amp is easy to install in the space behind the stereo and it uses the factory speaker wiring. You don’t need the amp if you have the factory speakers, the head unit sounds fine with those. But if you’re upgrading your speakers, it’s nice to have 45w RMS per speaker instead of 18. If you’re looking to get an amp like this, Alpine has a newer model that do e s 50w RMS and it’s cheaper. I recommend using the speaker line inputs to run signal to the amp and setting your gains with a multimeter.
I added the line driver because the RCA outputs on the head unit are pretty low in voltage. This allows me to increase the voltage so the subwoofer can run at less gain and results in cleaner signal and bass output from the sub.
The Rockford powered sub is a nice unit that will give you plenty of clean bass without breaking the bank. The box looks nice, much nicer than carpeted boxes IMO. The sound from it is great and it has a remote bass knob I’m I have mounted in the glove box. Another great thing about this sub is that the power and RCA wires are connected with easily removable harnesses. So if you need extra cargo room, you can remove the sub easily and not worry the power/ground will arc.
This system has been put together piece by piece over the last several months. I’m happy that it’s finally done and I feel like I have all the boxes checked for convenience, modern features, and decent sound quality.
Absolutely, as long as you purchased the exact same unit as the link in my post. Unfortunately there’s a lot of look-alike units out there and I won’t be able to help you much if you got a different brand. All these Android head units are not created equal. If you ordered a different brand, I would strongly suggest you send it back and order the one I provided the link to.
Ummm, you don’t. With CarPlay or Android auto, it’s using your phone anyways. So if you go to texts and want to send one, it’s gonna give you the list of contacts as it appears in your phone. If you’re using the Bluetooth phone app, it shows your contacts in the list on there.
so there’s no need to “import contacts” to the head unit. Not even sure why you would need that feature on a stereo. Perhaps you can explain what it is you’re trying to accomplish and why?
I’ve got an Android 10 unit, so things may be a bit different, but:
Open the Bluetooth app on the head unit, and pair the head unit with your phone. As long as the phone is paired, your contacts in the phone should be available in the Bluetooth app, and you can use those contacts to dial. If you have a microphone on the head unit, you should be able to use it to talk on the phone, and listen through the speakers. You may also be able to voice dial.
I haven’t tested this out much because I almost never use my iPhone in the car, except for CarPlay or as a hotspot for the head unit. My main reason for a cell phone was to talk to my wife before/while coming home after work, but she passed away about 5 years ago.
Quite a change from the handset and cradle with a box in the trunk that I had in the early ‘90s…
It's an android unit.. for future reference just use your Google account on the stereo. And sync it. It'll upload all your saved contacts. You'll need to log in to access Google play anyways. It'll need wifi access either through your phone(hotspot), or your home wifi. Needs wifi to check for system updates as well.
Mine works with Tubi, and Pluto when parked with wifi access. It'll play ripped dvd's with an android friendly player plugged into one of the usb ports as well..
First thing I replaced when I bought my Patriot. It had the factory am/fm CD player.
You'll need to log in when you open the Google play app the first time. It did a auto sync when I did. Some apps will only open, but no content even when parked.
I've had no problems with the andriod system in the 18 months it's been in there. VLC plays ripped dvd's without needing continual code updates. Even while driving. I also put a 500gb thumb drive with my audio library on it.
