An erratic temperature gage, engine temperature warning on, a potential invisible leak. Have you heard this story?
Background: 10 days ago, just before a ride from Montréal to Ottawa and Toronto, my son's 2009 Pat 2.4 cooling suddenly decided to act up and indicate overheat. After inspection, the indie ruled out headgasket (oil was not contaminated, nor was the coolant), coolant was missing, no obvious leak and quickly pointed fingers at thermostats. Indeed, one failed test, both thermostats were replaced. Top off and off you go happily on a 1200km ride.
On the way, engine temperature warning came on frequently and temperature gage moved erratically between C and H. Coolant had to be added about every 3-4h in the reservoir. No obvious leak was observed and the engine performed normally (no loss of power, no strange behaviour).
I am suspecting air in the system. Now, my question:
How do you bleed/burp air potentially trapped in the upper part of the radiator? Here the intake is about midway and no outlet in the upper part of radiator. Even with the front of car elevated, I don't see how air can get out. That's nearly 1/3 of the cooling surface (picture is an identical part). Any clue? ...and no, flipping it over to its side is not a solution 😅
