2011 Jeep Patriot 2.4 Automatic (CVT) with 111,000 miles
Issue:
From parked the car jerks a bit like something is sticking and then as I accelerate 1015 it smooths out and then there is no issue until we have to slow down to a stop and at low speed (less than 10) it jerks a bit before finally stopping.
I thought that it might be the coil packs because I replaced the spark plugs 9 Months ago and that solved the jerking between 35mph and 45mph. In Hind sight should have done both. I just did those thinking that might solve the problem, it did not seem to make a difference. Would the new spark plugs wear out in 9 months if I did not replace the coil packs at the same time.
at an oil change a year ago they said a have a tear in my right "CV shaft boot and grease is leaking". Is this the same as my so called "sealed CVT transmission"? I am wondering if my transmission fluid is low because of the leak?
We did have our Summer Michelin tires put on a few weeks ago however my wife has taken it back to have the tires check by Discount Tire after 200 miles and they said everything looked fine. She drives the car daily and can not tell me if it started after the new tires were put on. We switched over from winter tires does a computer or sensor need to be reset? I cant think of one but its a thought.
Rear Brakes were done around Christmas because the fronts were still good. Backs was really bad.
Could the Throttle body by corroded? I saw that as a possible option on here but the symptoms were not exactly the same.
Any insight would be appreciated. Thanks
Issue:
