Hi, welcome to the forums.
Others have had vibration issues, but they're usually when stopped while in gear, like at a stop sign.
If the hood is bouncing around while you're driving, the hood stops may need adjusting.
This thread might be helpful:
I was waxing the hood the other day and I noticed something really interesting. I popped the hood to wax the top edges of the fenders and while I was doing it I couldn't believe how much the hood wiggles when released to the safety catch. So I got to pressing and wiggling and thinking, noticing...
www.jeeppatriot.com
I'm not sure which transmission you have, but whether it's the CVT or the 6 speed automatic they both need service from time to time.
On the CVT the fluid and both filters(there are two) should be changed @30k miles, then 30-50k thereafter depending on driving conditions.
Towing, temp extremes, mountain driving, etc. means sooner changes.
Dealers will charge $400+, independent shops might be less, or you can DIY.
More info here:
Been done to death but I cant find all info with links etc to know i'm on right track. Want to service the CVT (replace filters and fluid) also have seen this 4 ports CVT Transmission Oil Cooler, 2 for Engine Coolant 2 for CVT Fluid. 2 pipes for the inlet/outlet of coolant 2 pipes for the...
www.jeeppatriot.com
