If you consistently replace the fluid every 20-50k miles with the right amount of quality fluid, you can most likely get 200k out of it, though there is ONE fatigue part that no number of fluid changes can mitigate.
The right level is critical. Too much fluid and the rotating parts churn it to foam, it doesn't do it's job, and boom goes the pushbelt.
Quality fluid is next most important. From best to near-best it goes; Amsoil, Valvoline, Castrol, Nissan. Those aren't just anecdotal favorites, those brands publish the specifications and test results of their products, and they rank in that order.
Mopar/Pennzoil should be avoided (Penn supplies Mopar), they don't publish any specs or test data for their CVT fluid, and there's plenty of reason not to trust it, or their recommended service interval. FCA used the Jatco CVT with the agreement that FCA doesn't touch them and Jatco replaces them. FCA has no interest in the longevity of these CVT transmissions, especially now that they no longer use them AND only a fraction of a percent of them are still under any kind of lifetime warranty. 99+% of blown CVTs at this point create a customer in need of a whole car.
Now, that fatigue part is the steel bands around the pushbelt. You can only bend metal, ANY metal, so many times before it breaks. The steel bands that hold the pushbelt plates are constantly bending. Since all the CVT failures that have been documented enough for RCA indicate lubrication failure*, I have no idea what the serviceable life for the pushbelt is. It might make it to 200k, it might not.
*Very early versions had insufficiently small ball bearings in the driven variator which would crack under load, seize the variator and then catastrophic failure of the pushbelt. No 2010 or newer vehicle has that version, but it warrants the asterisk footnote.
