21 - 29 of 29 Posts
Discussion starter · #23 ·
Alright, I have the transmission, and ptu installed again. Getting that sucker lined up was hard, and getting bolt through that rear transmission bracket too....
I am just getting ready to put the axles in and add the oils. Any links for the type of fluids to use? Also I noticed my throttle body looks like poop.
92131
Discussion starter · #27 · (Edited)
Well bad news boys. I don't think my issue was the clutch or throw out bearing. The jeep worked for about 60km and the refused to go into first gear. I can start from a stop in second, third, and fourth. When I put it into first it and let the clutch out gently it grinds and kicks out. I had suspicions that there were problems inside the transmission as it was physically hard to feel for the gears when shifting.
That sucks!
Discussion starter · #29 · (Edited)
I have a compatibility question. Will the motor and manual transmission of 2016 patriot be compatible with my 2011? The transmission in mine is broken. I have found a 2016 patriot for sale that had an interior electric fire. The 2016 has 44000km and is beyond repair. Wikipedia says the 2016 has a magna t355.
92210
92211
21 - 29 of 29 Posts
