Need some help identifying an issue with my 2016 Jeep Patriot Sport. When put in gear it judders really bad and feels like it doesn’t want to take off like very slow acceleration than it shakes.
That’s the strange part there’s no transmission codes and I hear something but it’s not super audible like before removing the brakes. I posted 2 clips of it.If the noise is coming from the transmission, then (along with the transmission codes) I'd say you're looking at transmission replacement.
You may want to take it to a transmission shop that knows Jatco CVT's for a second opinion.
YeaThere were transmission codes in the pic you posted (p0777 / p0717).
The shudder / judder (belt slipping) is a common sign of transmission failure as noted on the Sonnax page.
I'd get a shop to take a look at it.
I'm going to take it to shop when I can but I was trying to exhaust all my efforts before doing so 😆The codes may have gone, but the problem persists, so the fluid and filters change apparently didn't solve the issue.
I may be wrong, but I think the transmission is probably shot.
But maybe a qualified shop can offer another insight and things work out for the better.
Ahh ok and the tranny was only at 60C when i checked. I went ahead and ordered a 9336 Dipstick thoughThe engine dipstick trick only works on fully hot fluid, like after a long drive and parked on a level surface. Then there should be a little fluid on the end, below the low engine oil mark. I use a universal dipstick from advance auto and I marked the various millimeter distances from the tip by scratching a line with a sharp tool. I did 10 mm increments starting at 10 to 20, then 5 mm increments from 25 to 45.
At minimum, the EEprom (#2 below) on the side of the valve body will need to be swapped from old to new or you'll get a mismatch error.is it plug and play if I can source a good low mileage one. Or will it have to be flashed ?
Is that internal or external ?At minimum, the EEprom (#2 below) on the side of the valve body will need to be swapped from old to new or you'll get a mismatch error.
OkInternal, you have to take the pan off.
Ok so I checked it again today except this time I let the transmission get to 55C. This time the fluid only showed upto about 20mmWant to give an update
Got the 9336 Dipstick and checked my levels and it seems off
Transmission was sitting at 43*C using the APP to monitor temps on a level surface and fluid still looks like it’s extremely low.
I measured 7QTs out when I drained and dropped the pan and I added 7QTs back.
I marked where the fluid showed since it’s hard to see as it’s clear.
My problem now is how many quarts is per mmWhen you add fluid, I'd suggest only adding it to the lower end or middle of the range. ie: at 55c, I'd fill it only to 30-35mm. In these CVT's less is definitely better than even 1mm too much.
Ok so I’ll start by adding some fluid by the OZ and see how it goesI don't remember how much per mm, but i'd say cups, not quarts. Since you're already reading fluid on the dipstick, just go slow until you get a feel for it.
Yes, low fluid can cause issues, like slipping.
Too much fluid, even just 1mm too much WILL cause the CVT to overheat, whine, and possibly limp mode. I took my Patriot into a shop to have my right front CV axle replaced because I wasn't able to get the old one to pull out of the trans. A few days later my CVT started whining, overheating, and putting the vehicle in limp mode. I couldn't figure out why. I ended up throwing a bunch of time and $$ at it, only to find out after a few agonizing weeks that the shop had put in just a tiny lil bit too much fluid to replace what leaked out when they replaced the axle.
I've seen you mention this before but I never had an overheat myself, for almost two years with 10mm too much fluid in above the high mark. The dealer did my cvt fluid swap. I didn't find this out until I changed the return cartridge filter and thought I'd need to add fluid back. Instead I sucked fluid out until it was in the middle for the temp.When you add fluid, I'd suggest only adding it to the lower end or middle of the range. ie: at 55c, I'd fill it only to 30-35mm. In these CVT's less is definitely better than even 1mm too much.
I remember reading on a Nissan forum that when too much fluid is in the CVT that it gets whipped up into a foam by some rotating part... can't remember exactly which part, and in it's foamy state cannot flow out to the trans cooler which in turn causes it to overheat. With mine, after about 15 minutes on the highway I'd end up in limp mode because of it overheating. I don't remember the exact course of things I went thru when trying to get it fixed, but I do remember that as soon as I removed some fluid all the issues went away and I drove it for 3 more years after that with no more trans issues.I've seen you mention this before but I never had an overheat myself, for almost two years with 10mm too much fluid in above the high mark. The dealer did my cvt fluid swap. I didn't find this out until I changed the return cartridge filter and thought I'd need to add fluid back. Instead I sucked fluid out until it was in the middle for the temp.
