Weak bearing
395 views 3 replies 3 participants last post by  Sandstone
Good day, question,
Are wheel bearings front and rear same part? I mean the complete "hub". Seems a company in EU is selling rear but cant find front.
/Lars
The front bearing is typically pressed out of and back into the the existing steering knuckle. Some front bearing kits will include a new hub\wheel flange but you can often reuse those as well unless the bearing went so bad that it damaged the hub. As others pointed out, you can also buy a complete knuckle assembly with bearing already pressed in.
