Hi,
I have a Patriot 2008 4x4 North Edition with manual transmission, built on June.
From what I read and understand from the operator manual, we have 6 systems that helps us in some driving conditions (summary):
1.- ABS
Control brakes pressure to avoid wheel lockups.
2.- BAS
Reduce distance braking by putting a optimum pressure (in emergency situation)
3.1.- TCS (engine)
If wheel spin is detected, brake pressure is applied on this wheel and engine power is reduced.
3.2.- TCS (wheels)
If one wheel is spinning faster than the other, a brake is applied and the torque is "transfered" to the other wheel that is not spinning.
4.- ERM
If you turn too fast, enough to lift both wheel, it'll apply the brake of some wheel and engine power may be reduced. Used only in extreme cases.
5.- HDC
Maintains the vehicule speed while descending hills (a fake "engine-braking", but using brakes instead of the engine compression). Used only on off road situations.
6.- ESP
Corrects over-steering or under-steering of the vehicule by using the brake on some wheels.
As you may see, all system are "ABS alike" but adapted for each situation.
Now, the difference between ESP normal, ESP partial off and ESP full off:
ESP normal:
ABS: on
BAS: on
TCS (engine): on
TCS (wheels): on
ERM: on
HDC: off
ESP: on
ESP partial off:
ABS: on
BAS: on
TCS (engine): off
TCS (wheels): on
ERM: on
HDC: on only if off road mode and shift lever to L, otherwise, off (only in automatic models)
ESP: off
ESP full off:
ABS: on
BAS: on
TCS (engine): off
TCS (wheels): on
ERM: off
HDC: off
ESP: off
As you may see, the only difference between "ESP partial off" and "ESP full off" is ERM, the Electronic Roll Mitigation, and I think it's the reason why we can't have a ESP full off when we drive above 35 mph, it becomes "ESP Partial off". But, if we go under 35mph, it goes back to "ESP full off".
For HDC (descent control), I don't have it, it's an option in "off road" package.
So, yes, me too, I don't see "ESP OFF" in the odometer. I had to depress to put in "ESP Partial off" and depress again and hold it for about 7 seconds and the squiggle line illuminate. Am I in "ESP full off" ? I don't know and I don't want to test it by turning aggressively on the wet grass or dirt roads, and see if the engine power is reduced and brakes applied, but maybe you can try it and give us some news
I'm better at it with my ATV... Hey, it's my first truck, I need pratice
