Sub-Frame replacement both front and rear for a 2013 Jeep Patriot Sport 4x4
1.1K views 16 replies 5 participants last post by  Treegrower
My Pat has 92,925 miles on it. I bought it from a dealer as a lease trade-in in October 2015 with 63k miles on it. The manufacture date of the vehicle was January 2013. Both my front and rear subframe are done. I have sourced what I hope are the complete parts for both sections and they come to $665. Does that seem reasonable or out of line? This includes both cross arms, nuts, bolts, bushings and trailing arms. Am I missing anything? If someone has done this replacement prior are there things that you needed that wasn't part of the complete kits?
Also, my Pat has a CVT, I seem to get a lot of hesitation recently when accelerating. I know that Chrysler did not recommend service until 120k but I intend to have it done at the same time as the subframe install. I read all the comments about the dual filters etc. Has anyone else noticed a hesitation problem? Personally don't like CVT's would rather have a geared transmission.
Does anyone have an idea of the labor hours associated with the replacement? I know my per hour labor cost and sadly I live in an expensive section of the country so my costs are not comparable with other ones I have seen in this forum.
Thanks
Max's Mom
Has anyone else noticed a hesitation problem?.
Hesitation on acceleration can be caused by worn spark plugs. The factory style plugs are only good for about 30k miles before they need replaced, so if it hasn't had a new set in a while you might add that to the list.
Your parts prices seem reasonable to me. I recently had the rear subframe replaced on my 2010 Patriot. I already had the 6 control arms (donated by another forum member). My parts bill was about $320 for the subframe, 2 sway bar links, and a bushing. Labor for the whole job was just over 6 hours.
Here’s a link to the Parts and Labor section of the Operation Charm service manual for the 2013 Patriot. Drill down to the Suspension section. The subframes are called cross-members.
[/QU
This information is amazing! Thank you very much!
Parts prices seem ok. Change the plugs and have the throttle body checked before looking at the CVT for problems, but the CVT is overdue for a fluid change. Drain and refill only, both filters replaced, NO FLUSH. However, if the fluid is changed this late, there's a possibility that you'll uncover some budding problems from waiting so long, and need a new transmission in 15,000 miles rather than 50,000 miles from all the sludge holding things in place. What you do with that information is your choice, but I would recommend keeping it in mind, and using Valvoline or Amsoil CVT fluid. Amsoil is definitely the best and a near-must in hotter climates such as Phoenix, Las Vegas, and Miami, but Valvoline is a reasonable second best and more than sufficient for milder climates such as you might find in the "rust belt".
Throttle body has been changed twice. Will do the fluid change only and replace both filters. I am in the southern Northeast so pretty temperate. No extreme heat or cold, I could use Valvoline. Thanks 👍
Update on my subframe replacement and accurate information on purchase date and mileage. I couldn't find the original paperwork when I started this thread so here it is. I bought the Jeep from a dealer on 10/28/2014 and it had 31,610 miles on it at purchase. The information I used originally was from a service done a year later at the same dealership.
So, I guess I should have gotten a second opinion before I freaked out and started buying parts. I was given the name of a repair shop in my area that specializes in Jeeps. I took it in so I could get a quote on the replacement labor and was told there was nothing wrong with my subframe just a little surface rust. The owner smacked it with a hammer and showed me it was just fine! He said my worry should be about the CVT based on the issues I was having with hesitation. :rolleyes: We are going to try and drain the fluid and replace it and change the spark plugs also, he knew enough not to flush the tranny.
Thanks everyone for all of your advice. Let me know if anyone needs a complete subframe replacement both front and rear with all the bolts and bushings needed. I will probably put this on Marketplace and see what happens.
Max's Mom
Regular maintenance and keeping up with the minor things is very beneficial, and one does not need to over do it. I would especially keep an eye on the CVT and change the fluid/filters every 30 to 50 thousand miles. Get your Patriot professionally oil spray rust proofed or learn to DIY it. My recent Krown visit got the owner so excited that he posted mine on Facebook to show how clean/rust free my 13 year old Patriot was.
Thanks for sharing the update. Great learning value for everyone.
