PSX24W Fog Light Bulbs....really?
45K views 17 replies 11 participants last post by  brianh
I was checking the 2011 Patriot owners manual and noticed that the new Pats come with the PSX24W fog light bulbs. I get the fact that they are more energy efficient and what not but I'd rather the standard halogen bulbs be easier to find/buy and replace/upgrade than have them "last for 8000 hrs" (according to Philips automotive lighting). Philips also states that the PSX24W can be used to replace the 55watt H3 bulb. Do you guys think the H3 can be used to replace the PSX24W in order to do a fog light upgrade? I don't know why they couldn't just stick with the H10 (9145) fog lights of previous years....IMO if it ain't broke, don't fix it!
Seems the Dodge Journey switched...er, I mean upgraded to this bulb in 2010. Apparently it allows them to use a very cheap...er, I mean light weight fog lense assembly. This means no glass lenses or metal reflectors to take the heat...oops, there I go again...I mean the new light weight assembly uses less power and is more efficient.
So while you may be able to put the old bulb back in, it might melt your fog light...dang...I mean you'll be using more power...which makes you an evil CO2 producer...or something.
I wonder how hard or expensive it would be to fit the 2010 fog lights into the 2011's spot. No wonder all US 2011's come standard with fog lights.... they are spending the same amount as before, but more people are getting "fog lights"
Also becareful because my new 2011 Dakota also has these for fog lights and the fog light lenses are plastic. MY research shows some people replacing the PSX24W with H16 9009 5202 but becareful because those plastic lenses acan melt. I replaced mine with some h16 35w yellow and I m still a little nervous.
#8 · (Edited)
I just noticed that link in the other thread for the $90 SMD LED replacements does specify a LUMEN output of 400. This does not compare favorably to the 500 lumen output of the typical PSX24w halogen bulb used on the 2011 Patriot fogs, and is downright terrible compared to the 900 lumen output of the earlier model year Patriot fogs.
http://www.v-leds.com/V-LEDS-6K-HID-WHITE-28-p8701564-3-2.html
Do HID or LED, you'll never look back.
HID's run near cool in comparison to halogens.
