Had my FWD Sport 08 about 2 months now. I occasionally hear a popping noise from the front of the vehicle when accelerating and braking. Just one pop or clunk and only happens occasionally. Sounds like it is coming from the right front wheel area. Could be the drive train or the suspension but it is hard to tell. Sound like something is loose and when I accelerate from a dead stop or brake and the vehicle is almost stopped it will make that popping or clunking noise as if something is binding and the tension is released when accelerating and braking. Reminds me of my 99 F150 that made about the same noise accelerating and braking. This was caused by the drive shaft spline that goes into the transmission which was binding. It binds up instead of sliding freely and would make a clunk sound. The Ford dealer greased it but only helped for while and they finally change the spline shaft. Just wondering if any of you had the same thing or any ideas.
UPDATE: 8/5/2008
Took the PAT to dealer. However I wasn't expecting much from them but they took it in right away and tighten suspension bolts and now good as new.
UPDATE: 8/5/2008
