Jeep wouldn't start two days ago.
1st and 2nd attempt - starter cranked, then all dash lights went completely off and came back on. After that, just heard relay clicking but no start.
Immediately checked with JScan - no codes. MIL (Check Engine) light wasn't on.
Checked relay box, ground connections, and battery voltage - showed 11.3V.
After charging, Jeep started normally. No MIL light.
Didn't want to risk it - installed brand new battery. Took it for a test drive right away.
At low speed (<10 mph) during a right turn, it stalled. Coasted to shoulder. Restarted fine but had rough idle. Then returned to normal and made it home.
Scanned with JScan again - only one(!) code: P0200 (Injector Circuit Malfunction).
Checked all wiring near injectors, relay box (mine's relocated near TIPM), and ground points. Engine idles smoothly.
Relay box and relays in perfect condition. Grounds are good. All injector connectors too. Even hit everything with Liqui Moly contact cleaner.
Big question: What's causing this? Could it be the CKP sensor (crankshaft position sensor)?
Now I'm scared to drive this thing... Help me out guys!
Jeep Patriot 2,4 4x4 2016 6f24
