381 - 400 of 469 Posts
Loving this set up. What's the wait with the tire and rim? Also would I be able to go with a smaller tire so I wouldn't have to do the pinch weld mod. Don't have the means necessary to do so nor know anyone in my area to help out.
Sent from my SM-G950U using Tapatalk
I haven't seen this rim on here yet so i figured I'd share it, its the ATX 201, 16 inch with 0 offset. The tires are KO2's 235/70x16r. Mine is a 2016 and the pinch weld mod is needed!
Sent from my SM-T800 using Tapatalk
Loving this set up. What's the weight with the tire and rim? Also would I be able to go with a smaller tire so I wouldn't have to do the pinch weld mod. Don't have the means necessary to do so nor know anyone in my area to help out.
I'm not really sure what the weight is but it is quite a bit heavier than stock, also not 100% sure but I'm thinking it does come in smaller sizes.
Sorry posted else where. Just trying to get some answers. Thanks!
Hey guys what size spacers are you guys using for that flush look? Gonna keep the stock 17" rims and tires now for awhile. Just got her 2017. If so tell me where ya go them as well and what fits the best! Dont want steering wobble as Ill want hub centric. Thanks for the help!
Went on Spidertrax but didnt have the Patriot listed.
Spacer sizes to look for?
Think 1.25" for flush?
Hub bore :67.1
Stud thread Pitch : 12x1.5
Wheel bolt pattern: 5x4.5 / 5x114.3
https://www.ebay.com/itm/182270970802
These work? ^^^^
Anyone?!!! This forum doesnt have much action does it lol
I linked you to this thread from your original one because questions like this are asked basically daily on this forum. New users show up, ask a question like yours that can be easily found via search, and then leave, never to return. I linked you to this thread as you could look through it, and see a ton of examples of stock wheels with spacers, and figure out what you want to run.
So I suggest you look through this thread, and use the search as there are dozens of pictures of Patriots on here running spacers.
I did. You wrote all that when you coulda just told me the answer im looking for. Lol
Spidertrax was zero help.
They reply " no we dont do patriots. Have a nice day".
Wtf. Ok then
Well I figured it all out. Will post pics soon as installed.
So tomorrow is the big day, I already sit on 235 70 16s on the stock steelies on a our 2016 4x2 - ordered Unique 297 wheels 16x7 with 0 offset - the tech already told me it wont fit without a lift, based on all the research I got from these forums I believe the pinch weld mod is most I need to do at this point, Im still hoping I wont have to do anything and that it will just fit fine, I just wanted the tires to come out more. fingers crossed!!!
Wtf. Ok then
Except "flush" is different to each person, (to some it's a 1 inch spacer, some it's 1.5) and then you'd ask more questions, or for pictures, etc etc instead of just looking through the pictures of Patriots with spacers and figuring out what you want based on what you like the look of.
Glad you figured it out, and it wasn't that hard now was it?
Tirerack and ATX website shows them as unsupported, any mods required to bolt them on (not size mod, pinch weld is not what I am talking about)
what was posted information, I wanted is not here -> ATX 201, 16 inch with 0 offset, The tires are KO2's 235/70x16r. Mine is a 2016 and the pinch weld mod is needed. Rest was just pictures. Thanks for nothing I have moved on
Just had some Hankook DynaPro 235/65/17 installed this last week. Does not seem to be rubbing even at full lock. Also does not have spacers or a lift...yet. Jeep is a 2015 Latitude 4x4.
