So my jeep is overheating after a 10 min ride into town or when sitting at a light idling. I have had to top off the coolant a couple of times in a month and the shop I went to said there aren't any leaks, the water pump is fine. I put the heater on full blast to keep it from overheating but even then the gauge goes up while idling. I asked if they checked the head gasket and literally got no reply. Any advice would be appreciated!
UPDATE:
After the shop ran pressurized air through the system to check for leaks it hasn't overheated. In fact, the needle doesn't even fully reach the center line on the gauge. Will monitor and update if needed. Thank you everyone for your advice!
UPDATE:
