There are two Jeep Patriot Maintenance schedules, depending on your driving conditions. Almost everyone I know falls into schedule "B" (see criteria below).
That means you should change your oil every 5000 km (3000 miles). In the real world you can probably stretch this out a bit, especially if you are using a 5W-30 synthetic such as Mobil 1 or Pennzoil Platinum.
Under no conditions should you try to stretch things beyond 10,000 km (6,000 miles). In that case you would be exceeding both schedule "B" and the more relaxed schedule "A" for less harsh driving conditions.
Schedule “B”. It is for vehicles that are operated under the conditions that are listed below and at the beginning of the schedule.
NOTE: If ANY of these apply to you then change your coolant every 170 000 km (102,000 miles) or 60 months, whichever comes first and follow schedule “B”.
NOTE: Under no circumstances should oil change intervals exceed 10 000 km (6,000 miles) or 6 months whichever comes first.
CAUTION: Failure to perform the required maintenance items may result in damage to the vehicle.
- Day or night temperatures are below 0° C (32° F)
- Stop and go driving
- Extensive engine idling
- Driving in dusty conditions
- Short trips of less than 16 km (10 miles)
- More than 50% of your driving is at sustained high speeds during hot weather, above 32° C (90° F)
- Trailer towing
- Taxi, police, or delivery service (commercial service)
- Off-road or desert operation
- Heavy loading
