2014 Jeep Patriot Latitude 4x4 FDII with Freedom Drive II Off-Road Group in Granite Crystal Metallic.
(After heading into the "big city" here today for some holiday cheer stock-up, I decided to take these photos before more snow arrived. I finished the winter-prep wash, detail, and seal this past weekend using the Wolfgang and Klasse line of products, as well as Aerospace 303.)
Options ordered with the vehicle:
Trailer Tow Prep Group; Premium Sound Group; Security and Cargo Convenience Group; Engine Block Heater; Smoker's Group (basically, an ash tray that fits in the cup holder! When I ordered it I thought it would give me a pull out tray on the dash that I would have used for various items, as I'm not a smoker. Oh well.)
Accessorisation:
OEM Jeep 16" black steel wheels #YX87RXFAA with TPMS and OEM Jeep black plastic covers #YX93RXFAB (These black steel wheels are newly offered for the 2014 Patriot Sport and were very difficult to track down as a dealer-ordered part. Turned out that the part was offered in 2015 part manuals, not 2014. I handpainted the "Jeep" center circle area with Testors aluminum paint);
215/70R16 Cooper Discoverer A/T3 (including full size spare);
OEM Jeep Wheel Lock Kit (#82210508);
OEM Jeep 1 1/4" tow Hitch Receiver #82213567AB with Trailer Receiver L-Bracket for connector #82213676 (Trailer Tow Prep Group did not include the hitch, just the wiring harness in a plastic bag in the cargo area);
OEM Jeep Roof Basket Off Road Lights #82210753, two lights each part number ordered twice for total of four lights (these are actually Hella FF75 with the "Jeep" name on the glass instead of "Hella") with OEM Jeep Off Road Light Wiring Kit #82210877AE;
Yakima MegaWarrior Basket with Yakima Light Mounting Brackets (4) (I had to measure replacement bolts, washers, and lock washers to get the correct drop height as these are mounted hanging from the Brackets. I also had to drill a hole in the bracket to get the correct fore and aft position.);
Rocky Road SuperSliders;
Road Sport Big Mudder Splash Guards #3102 (these were a bear to get just right even after using my wife's factory Deluxe Molded Splash Guards as a template. The fronts had to be measured and cut, etc., but they fit great and will not crack, snap, or break when I crawl over things - thanks to "the_jeep_now" for the heads up on this item);
NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug installed on the lower left front bumper. I drilled a 2" hole and mounted this to the left front plastic bumper just to the left of the tow hook opening. I then ran the cord directly up inside of the bumper, behind the front left headlight assembly in the engine compartment, where I connected a Conntek RL-30104 U.S. 3-Prong Heavy Duty Dual Outlet Adapter. I then connected my factory engine block heater cord and the factory accessory battery blanket cord, secured with zip ties for a very neat installation. I lubricated outside and inside of the Port Plug cover with clear silicone grease, as well as all of the male and female cord prongs and connectors for an all-around, well sealed application. Now I simply walk the AC extension cord from the garage outlet (I use a timer) and plug it in to the Port Plug without ever having to open the hood or having to get on the ground to find dangling cords and outlets from under the body.
Rugged Ridge All Terrain Front (#12975.25) and Rear (#12950.17) Floor Liners and Cargo Liner (#12920.30);
OEM Cargo Tote (#82208566); Cargo Net (Floor Convenience and Envelope Net (#82210538); Vertical Convenience Net (#82210641);
OEM Jeep Battery Blanket (#82300778);
Jeep Trail Rated Medallion (#55157317AB) added to right side fender.
Future Planned Accessorisation:
ARB 2000 Awning off the left side of the MegaWarrior using FourTreks brackets and a ScanGauge. After that, I'm Done! I mean it. Save for an overlanding trailer, ARB fridge, ...
I hope the part numbers are helpful to anyone that might need them - it took me many hours to come up with these when I was initially researching these parts and others.
