Hello,
I have one here you all...
I own a 2016 Jeep Patriot Latitude Edition 2.5L. My check engine light is on and has been coded. The codes are P0302 & P000A. The engine rough idles and takes awhile to accelerate. When at idle the engine can occasionally die. After engine dies, car will just turn over but not start. Pulling both connections on the PCM, waiting a few minutes, reconnection, engine will start. Sometimes the dash lights and headlights flicker while idle, until you accelerate then flickering stops.
Things I have tried/verified.
I have not checked the fuel injectors to rule them out yet. I am considering its a bad PCM, but I don't want to sped $200+ on part that could very well not be it.
Thanks in advance!
- All coil packs and spark plugs have been replaced.
- Timing chain is tight and has no slack or visible damage.
- Engine has oil (does need to be changed).
- New battery and contacts clean.
- Camshaft and crankshaft positions sensors changed in the past year.
Thanks in advance!
