I have been driving my 2010 Jeep Patriot Limited for almost 2 years now and here is a compiled list of current issues that i have with my baby girl lol.
JeepFaults
Hood not aligned.
Leaking/Spraying from radiator cap.
Leaking from engine oil cap.
Power steering seal worn.
Engine splash guard missing.
O2 sensors are bad.
Catalytic Converter bad.
Whistle/Shaking in the engine.
Horn doesn’t work.
Flashers don’t work.
E-Brake on back tires dont work.
Rubbing sound from front tires.
Steering wheel misaligned.
Pulls to the right.
Seat heaters don’t work.
12V plug in works intermittently.
Cruise control doesn’t work.
Back 2 TPM’s work for short periods of time.
ABS, Traction Control/Stability Control and 4WD lights come on in warmer climates.
Rear passengers tire doesn’t hold air.
HVAC takes a few minutes to flow through the tubes I’m wanting when first turning air/heat on.
HVAC only works on full blast.
HVAC constantly blows at whatever temperature I’m wanting when HVAC is turned off.
Drivers door squeaks.
Squeaking/Knocking on back right wheel.
Tie rods and ball joints are bad.
Rear splash guard missing.
Touch screen on stereo only barely works on right bottom portion of screen.
RPMs between 1.5 and 2 when starting after a few hours of rest. Dies down within 2 minutes depending on weather. Last longer when colder.
Gas cap won’t stay tight.
Misfires when parked or holding the break for too long.
JeepFaults
Hood not aligned.
O2 sensors are bad.
Horn doesn’t work.
Pulls to the right.
