On Monday the 12th my we bought my wife a 2008 Patriot 4x2 with 118,000 miles. Wednesday the battery light came on as my wife was leaving work. It died as she pulled into the driveway. Jumped it off with my Cherokee and the light was out but was throwing DTCs P0700 and P161B (if I recall correctly).
The seller told us he had the alternator replaced due to a bad bearing so we called the dealer we purchased it from and he took it back to the shop where he had the alternator replaced. Thinking he left a wire or something loose. Got it back Monday and was told that the alternator was installed properly and everything was tight.
Battery light came on again on Tuesday afternoon. I scoured Google and forums to help figure out what was up. Found posts mentioning the same DTCs and bad battery connections. So I removed the battery and cleaned the posts and terminals looking for corrosion, but it was clean.
I found posts showing bad connections at the starter so I looked at that and I did find the jacket was partially missing on the yellow wire that connects to the solenoid via spade connector. I put some heat shrink on the bare wire and tightened up the connection and thought EUREKA I found the culprit.
Alas the battery light came back on this evening while I was cleaning the interior. I had it idling in the driveway with the A/C running.
The car was sold As-is and my wife is upset. I am sure this is something simple, but we cannot find the problem.
I have noticed that each time it has occurred, it has been late in the day when it was warmer outside, not yet experienced in the morning. I will check if it is on tomorrow morning, and update this thread. If it is on and stays on this will help the shop diagnose it quicker, at least.
We really like the car, and don't mind paying for a repair, but I don't want this to turn into a money pit at a dealer.
Anyone have any suggestions?
