Hydraulic Jack Height Recommendation
11K views 6 replies 7 participants last post by  karlo
I have 2014 Patriot with 17 inch wheels and am still running the stock tires. Stock suspension (no lift kit).
I am looking to purchase a hydraulic jack to make it quicker and easier to get the jeep up on jackstands for when I rotate the tires, work on the brakes (eventualy), etc.
Most of the jacks I have seen have a max lift height of 13 or 14 inches. Based on the specs above is 14 inches enough? or what should I be looking for with regards to hydraulic jack lift height?
Thanks,
Z
I agree with Sandstone. The 15 inch capacity is enough to get the tires off the ground on my Pat with 16" wheels. You can gain 3 inches easily with some blocks of 2 x 6 lumber. Even the 20 ton models only gain you 3 inches.
At some point, its safer to go to a floor jack if you are looking to get 20" or higher. Unlike Sandstone, I don't like using the pinch weld to jack on, so I use other points. I've seen too many bent pinch welds....but that's just my opinion.
