High rpm with high speed drive
2.6K views 7 replies 3 participants last post by  Islam
I have 2012 Jeep patriot 2.4l 4x4, I think I have high rpm with high speed, at 80km the rpm 2500, at 100 km the rpm 3000 , at 120 km the rpm 3500, knowing that no high noise at the engine or transmission, no engine light even the mechanical check it with drive tester no any code!,, any idea about that ?
It's ok, the RPM will be higher, no problem. Mine is also the FDII off road and it does the same thing.
Just make sure you keep up on transmission fluid and filter(s) changes, should be every 30-50k miles or 50-80km depending on driving conditions.
More info on fluid and filter changes here:
Th
thanks a lot I was very worried, because I just bought it and I thought I have big problems, from 2 weeks I search for answer but didn’t find
Yeah, the FDII models run at higher revs and use more fuel than the other models... what yours is doing is normal.
