Here's what it took to be able to flat tow my 2017 Patriot 4x4 four down.
5.6K views 4 replies 5 participants last post by  Sandstone
We had to tear the front end off to be able to have room to install! Here's what I bought to get this done: I bought everything through eTrailer online - I included the part numbers in case someone else is looking for similar products. BX1130 Blue Ox Base Plate Kit - (Removable Arms) <$425.00>, BX7365 Blue Ox Alpha Tow Bar - Motorhome Mount - 6,500 lbs <$720.00>, RM-15267 Roadmaster Diode 7-Wire to 6-Wire Flexo-Coil Wiring Kit <$136.00>, RM-156-25 Roadmaster Battery Charge Line Kit for Towed Vehicles <$30.00>, RM-88400 Roadmaster Brake-Lite Relay Kit for Towed Vehicles <$30.00>, HM39530 Brake Buddy Stealth Supplemental Braking System - Proportional <$950.00>, RM-154 Roadmaster Universal Hy-Power Diode Wiring Kit <$73.00>
90516
We had to tear the front end off to be able to have room to install! Here's what I bought to get this done: I bought everything through eTrailer online - I included the part numbers in case someone else is looking for similar products. BX1130 Blue Ox Base Plate Kit - (Removable Arms) , BX7365 Blue Ox Alpha Tow Bar - Motorhome Mount - 6,500 lbs , RM-15267 Roadmaster Diode 7-Wire to 6-Wire Flexo-Coil Wiring Kit , RM-156-25 Roadmaster Battery Charge Line Kit for Towed Vehicles , RM-88400 Roadmaster Brake-Lite Relay Kit for Towed Vehicles , HM39530 Brake Buddy Stealth Supplemental Braking System - Proportional , RM-154 Roadmaster Universal Hy-Power Diode Wiring Kit View attachment 90516
Can you please share the install of the Brake Buddy Stealth system. I am trying to figure out the brake booster part. If you can send pics that would be great too. Thanks
