Engine Oil Issues??
8.3K views 18 replies 9 participants last post by  JeepCares
I've been kind of freaking out and need some direction here. I've been searching and searching and cant find anything similar to my concerns.
I very recently purchased a used 2014 Jeep patriot sport 4x4 - 2.4L FD1, with 14,000 miles from a reputable dealer. After purchase, I got the oil changed and the car inspected, all was great. I then took it on a week long, 700 mile trip with my family through the mountains. When we got back I went over the vehicle and checked everything out. When i checked the oil, it seemed to be very, very high and smelled of gas. The motor was cold. I then ran it for just a moment, pulling it out and back into my driveway, checking the oil again after I turned the car off. The oil level at this point showed to be in the "safe" range, but still smelled of gas. The next morning after the car had been sitting all night, the oil again showed as way too full on the dipstick. I didnt notice any froth or milkyness at any point, but i only checked the oil by using the dipstick.
I haven't necessarily noticed any issues while driving it, i thought it did great on our trip. No warning lights on the dash panel and it's been operating at proper temperatures.
Am i freaking out about nothing here? This is my first almost new car so I'm a bit paranoid about everything.
Any thoughts/ideas??
Yeah, I saw that too, and was thinking maybe that's just what you get when you take a cold reading. But I've seen other threads here where users say their hot and cold readings are almost the same. I'm seeing a huge discrepancy between the two, to the point where I'm too concerned to drive it at all. I would take it into the dealership but everybody is closed on Sundays.
Strange, very strange indeed.
Pardon me for asking an obvious question, but is your Jeep parked on level ground? That would affect your dipstick level.
What color is the oil? With only 700 miles since the change it should still look clear/light amber.
I never heard of checking the oil when its hot. I usually check it before I start it for the day figuring any oil up in the cylinders will drain down overnight. I wonder what FCA's thought process is in recommending that?
As for me, I don't worry much, and with a vehicle as new as yours it seems unlikely you'd have a significant problem. Still, if you're nervous, it probably wouldn't hurt to have the dealer look at it. God forbid it develops a serious problem,at least you'll establish a paper trail that says you didn't neglect an unusual symptom. And I'd call what you're having unusual.
#6 · (Edited)
Thanks for the responses. Yes, it was parked in my garage on level ground when I checked it. The color is still pretty light. And I did just get it up to operating temperature and checked it again and it was still high, and i did see a few bubbles on the dipstick, so maybe treegrower is right and it was overfilled when I got the oil change - I'll now always be checking myself in the future.
But the oil still seems to smell of gas, and when compared to my 2008 mazda 3, the exhaust smells pretty rich. Is it possible for unburnt fuel to leak into the oil pan? Maybe a VVT or injector issue?
If it is just overfilled, what kind of damage might I have done driving it that way for 700-1000 miles?
Although I've never heard of anyone else here having an issue suimilar to yours, its entirely possible that something is up w/ your fuel system; maybe a stuck injector.
I'd get it to a reputable mechanic for an inspection. If there's gas in the oil, especially in the amounts you're seeing, it could certainly do some damage.
I'm in the opposite boat - I've never owned a vehicle that DIDN'T want you to check it hot. I was under the impression that you always check oil with the engine off, at operating temp. Unless you're desperate and just want to make sure there's actually oil in there.
There's 2 maintenance schedules. The manufacturer's schedule as listed in your owner's manual, and the Dealers Service Department schedule as listed on their big sign in the drive-in bay.
The Manufacturer's schedule is designed to keep your vehicle in factory operating condition.
The Dealerships schedule is designed to extract every possible dollar out of you for the life of the vehicle. Follow the Manufacturer's schedule...
