CVTF+4 Transmission
6.3K views 7 replies 4 participants last post by  Sandstone
now I have Genuine Chrysler (5191185AA) CVTF+4 Transmission Fluid in my car so I wonder flush done then can use
Valvoline Transmission Fluid CVT in fresh ?
Yes, Valvoline CVT fluid is compatible. You don't have to do a flush, a simple drain and re-fill is good enough.
Also, make sure you change BOTH filters, especially the cooler filter on the side of the transmission under the "soup can" or the bypass valve plate (below).
I've heard a flush can ruin a CVT. Might be they use the same machine as with regular transmissions, maybe not, either way the CVT is....incredibly picky. Drain and refill for sure, couple cases of Valvoline or Amsoil so you know you have enough in case of spillage or a slight leak and you're good to go.
