Bull bar/nudge bar
5K views 4 replies 3 participants last post by  Sandstone
Hi, I’m in the UK trying to find a suitable bull bar to fit. The nearest I can find is for a Cherokee. Does anyone know if this will fit and, if not, where I can find one that will?
You will have to fabricate new mounts since the mounts used are for a WJ. Also the bullbar mounts under the fascia so you will lose any approach angle you had with the Patriot if you off-road. There was a guy on the WJ forums who made new mounts which would use the tow hook attachment points on the WJ's to mount the bar higher. Also too those bars are spread wide enough that they cover up the fog lights on the 2nd Gen Pat's.
Thanks KF2M, I have a friend who is a fabricator so I’m sure he can help. In the meantime, I guess I need to take some measurements to ensure I don’t cover up the reg plate or the fog lights. Thanks for your help.
