4WD! ABS Traction control lights, trans acting funny, help!!!!
11K views 6 replies 4 participants last post by  ems977
hello, i have a 2010 patriot, a few weeks ago i noticed that my 4WD! and traction control light came on, both came and went, seemed like the more rough roads i drove the more it would happen, i have not troubleshot the issue yet, as i havent drove it very much latley. however this morning i hopped in to take it to the gas station and top her off, and i noticed my transmission, seems to be kicking down and then the abs light comes on with the 4WD! and traction control, but this time they flashed and it felt like the trans crapped out, but when i put it into "manual" mode, it shifts fine. i obviously have an issue. but am clueless as i dont have a fancy computer to diagnose. would a bad wheel speed/abs sensor cause the trans to act up? any help would be great!!!!! i really dont want to get rid of it , especially if its an "easy" fix. thanks.
UPDATE: i did scan it with my scanner and i got:
P04020- Catalyst 1/1 Efficiency
P1128- Closed Loop Fueling Not Achieved -BANK 1
ABS:
C1032- RR Wheel Speed Sensor Signal Erratic Performance
C1044- RR Tone Wheel Performance
i hope this helps, obviously i have a bad speed sensor, not sure what the "tone" part is about, or the closed loop fueling.
These might help:
