1 - 20 of 273 Posts
moparnumber1
· Major Modificator
Username- Moparnumber1
Year-2008
Make-Jeep
Model-Patriot
Trim-Sport 4x4
Color-Green
Mods-
01:BC BR Type Coilovers
02:Yokohama S. Drive tires 245/40R20/ XXR 968 20x9 Machined Silver wheels
03:Hifonics 1500 watt (@1ohm) Mono block & Alpine 4 Channel Amplifier 475 Watt (@2ohms)
04:Custom tablet install-LG Gpad 8.3" Tablet running KitKat-Jailbroken, but OFW
05:Alpine Type S 6x9's
06:pyle Supertweeters
07:2 NVX 15" Subwoofers- Rated 144.5 Db at 42Hz in a 5 FtÂł vented Superboom style box.
08:Wolo Truck Air Horns with dual compressors
09:Quad Brake Lights
10:NVX 7 band EQ custom installed in dash (Replaced Hazards/ESP location)
11:Roof Rack Delete
12:AEM Brute Force Air Intake System
13:Glasspack hidden exhaust system)
my Jeep is green. quad lights were uber easy. go to your local auto parts store and get a couple 3157 housings (most have gm brand), a couple 3157 bulbs, and at least 6 "T-Taps". then take your brake light housing off. on a piece of paper, trace the 3157 housing so you can cut a template. then trace that template on the back of the bottom of the housing where the rear fogs (euro models only) go. cut it out carefully and plug in your new housing. then take the wiring and using t-taps you can tap into the stock harness without cutting. the computer doesnt care about the extra load so dont worry about getting leds. I would have done a write-up but I dont have a dremel, and my leatherman was in Oregon getting repaired, so i drilled a bagillion little holes with a tiny drill bit and used a razor lol. it took FOREVER, and looks hideous, but it works :)
Thanks for the info. I've got a rainy day mod to work on in the future. I may get fancy and do a write up, we shall see. :)
it's the #1 mod EVERYBODY with a Pat should do! you can even take it further and add a couple more backup lights to the extra clear lenses if you dont have independent turn signals. I may do that later on just to fill it up. Some people even put fog lights in there on a separate switch.
Haha I love the story behind the home, sadily my works and my dreamland are both out of order, so I shall be doing a Jackson for them too when I get the time todo thjs:) thx for the info!
Just waitin' on that bezel!
got the mic wired and attached to the drivers a-pillar. I'm diggin it, except the display wont show songs played on my phone if I use Winamp, so its back to the stock S4 player...
Discussion starter · #10 ·
Stereo is lookin' sexy!
FINALLY got my H&R Lowering springs in from Creation! Thanks for the packing peanuts, they exploded all over the place when I ripped open the box lol! I'll give em to my dad for his business.
Its raining here, but I might just say screw it and install the springs early tomorrow morning. Shouldn't be more than a couple hours, but it is a Chrysler product... something is bound to go wrong :p
Discussion starter · #14 ·
Mine had t30 torx bolts, just put em back in... they still had quite a bit of locktite left on them. I do actually want to get some flat rivets and silicone them in. I dont like how the bolts stick up. Now I just need to figure out how to remove the calcium build-up on the roof without killing the paint..
WOOO!! No more bulky bolts sticking out!
Also got a box for my much needed 10's, so now I get HIGH bass! (If you know what D&B is, you'll know bass fluctuates often in that genre.) Only $30! Split, sealed, 3/4" MDF. Pretty good for under $50.
Still need to finish my 12" box.... :/
(Dont worry, bass is OFF when kiddos are in)
i like the setup, thats the best postion ive always felt for subs anyways, shoulda make the box fix the back more flush tho :p, also did you blow the old subs?
1 - 20 of 273 Posts
