I have a 2007 Jeep Patriot with the 2.4L engine and it’s still going strong and nearing 200k miles.
If you are looking for a larger capacity oil filter over the stock size, I can confirm that the WIX 57045XP fits just fine and still stays fairly protected from road debris inside the plastic shield under the front bumper.
WIX-57045XP
Thread Size: M22 x 1.5
Height (in.): 4.828 in.
Outside Diameter (in.): 2.939 in.
Filter Bypass Relief Valve: Yes
Anti-Drainback Valve: Yes
Relief Valve Open (psi): 12-15 psi
It is just the right height as any taller in height exposes the bottom to road debris so I would not suggest finding anything taller.
WIX-57045XP
