Has anyone else with a 5spd manual had a top gear acceleration whine? I have brought my Pat in to the dealer twice now for this and now they are saying it is a normal sound and they can't/won't fix it! They themselves went on a test ride and heard the noise, which occurs in 5th gear only and when you depress the gas pedal, as soon as you lift your foot the sound is gone until you step on the gas again. It is a high pitched sound that resonates throughout the interior and drives you crazy. The service supervisor called it "a top gear acceleration whine" and said it was due to the way the gears are cut. In top gear he stated that two gears must be touching in a way as to whine. He drove a Dodge Caliber with the same transmission and said it made the noise worse than my Pat and that I should be content with mine!! He wasn't willing to put in a new tranny because he is convinced it would also make the whine noise, maybe worse. He said there is no TSB for this and no reports of other owners complaining about this either. Is there anyone else out there experiencing this? Any suggestions would be greatly appreciated!
