Way over payload
3K views 5 replies 5 participants last post by  ColoradoMan
Last weekend I was way over the payload of the patriot. Is there any side affects I should keep an eye on? I had 102 pavers weighing 18lbs each and me driving. I guess the payload for the patriot is 1,130 lbs - max.
If you did it one time only, probably nothing to worry about. Its like drag racing away from a stoplight -- you do it once, no big deal; if you can't stand being second away from a light your Patriot will get old prematurely.
Overloading it once is naughty; doing it all the time is bad. Consistently overloading it will cause premature wear throughout the drivetrain and weaken the suspension parts (just read a parts list), and wa-a-ay overloading it will cause immediate problems, e.g. clutch/transmission, broken springs and blown shocks.
My guess is you probably got away with it. Slap your wrist and don't do it again.
#3 · (Edited)
Pick up an old pickup for those type of large hauling jobs. I bought a one owner '87 Dodge Ram D150 (225 ci slant 6) for $1,100. No rust, 80k miles. It can take a ton of weight a lot better than a passenger vehicle like a Patriot, plus the stuff is in the back and not dirtying up the interior.
It's a half-ton, but it has helper springs added to the rear leaf springs. I've had a ton of gravel back there and it did fine -- won't win any races with a loaded down inline 6 truck. But I think the torque is almost as much as a 318ci V8. Plus it makes a good tow vehicle. It could probably tow up to 4,000 pounds safely.
