41 - 43 of 43 Posts
This post just helped me out. Whenever i would make a left turn i could hear water hitting the fan blades and when i would brake i would hear water sloshing around behind the dash. And the padding under the blower was wet and there was water on my rubber floormat as well. So i pulled the drain hose from behinf the gas pedal and took some small steel wire and pushed it in there and it started dripping and when i pulled it out 6 cups of nasty murky water gushed out and now everything is back to normal
Finally fixed the water sloshing/hot water on the feet. It's just as described above. The drain tube had so much crud in there, I cant imagine how it got in. Here are some pics.
It's the L shaped tube next to the gas pedal.
Debris doesn't like to round the bends.
This is where it drains out.
All the crud! I took it inside, blew it out into the sink and rinsed it out.
These pics were exactly what I needed. A little tug and an air hose got it all cleaned out on me 2011 Patriot. Thanks!
Just to give reference on what size stuff can block up that drain tube, I pulled mine off to see what was causing water to pour into the car and found a .22 casing that must have been from our last visit to the range. Lol
41 - 43 of 43 Posts
