What's the max tire size I can run on my Pat. It's fwd with no lift. Willing to modify the pinch weld. 225/75/16 too big?
Welcome @Jhonbm! The member who posted that photo hasn't been on the site in several years. However, maybe someone else can help you. As I noted earlier in this thread, the biggest tires I've run were 225/75-16. I did not do any modifications and I only got a slight rub when backing up over some pretty big bumps. I never noticed any problems when going forward.Hola buenas noches tengo un jeep patriot 2008 2.4 , qué número de aros y de llantas me recomiendan colocarles sin modificar el carro pero quiero que quede ancha las llantas asà como este que voy a enviar una foto 👇🏻 , por favor ayuda gracias View attachment 99607
Those are pro comp wheels and 235/70/16 KO2 tires. They have to pinch weld to make them fit.Hola buenas noches tengo un jeep patriot 2008 2.4 , qué número de aros y de llantas me recomiendan colocarles sin modificar el carro pero quiero que quede ancha las llantas asà como este que voy a enviar una foto 👇🏻 , por favor ayuda gracias View attachment 99607
Check out this combo. This should be a good candidate even without a lift. Check out 171 ion wheels if you like that style of wheels.Did the RRO lift kit, pinch weld mod. and now running All Terrain tires on 8" ION 133 wheels (offset -5) 245 x 70 x 16" no rubbing problems. I ran this tire and wheel combo before the lift kit without problems. My one concern was the limited clearance between the rear tires and the fender as this combo does stick out the fenders.
