The struggles of FD1 vs FD2
14K views 66 replies 17 participants last post by  Tyler-98-W68
Last weekend I went offroading with another member from this forums and I can definitely tell why FD1 isn't as good as FD2. He had a 2010 FD2 and I just had my 2011 FD1.
I think the main thing that really lags in FD1 is the lack of low gearing. There was 2 obstacles where I was definitely burning my cluch trying to get over some rocks where as the FD2 just rumbled up over them. Also the lack of a lower backup gear is frustrating even in parking lots and such. It seems like twice as high as the first gear and I really never can lift my foot entirely off the cluch when backing up unless i want to go flying. Definitely not good for offroading.
Other things like tires help out a ton too. I just have the all season tires and those obviously dont perform as well as the tires that come on the FD2.
Things I was impressed with that are just ABOUT as good on the fd2 is the four wheel drive system on fd1. FD2 has those break locks which are better but I really don't believe they are better by much. They also seem to give some trouble with locking up too much. The FD1 system works great. It will have tires spinning in the air at times but still can supply enough power to the tires on the ground to get over things.
I also am impressed that the 2011 FD1 has the same ground clearance as the FD2. I bet I would have been scrapping bottom with the 2010 or earlier FD1s
Tow Hooks would definitely be nice on the FD1 and skid plates but at least I have some plastic skid plates on the FD1 that came with it.
I really haven't found the need for the FD2's extra oil cooler. My engine never heated up that much eventhough I pushed it to 5-6k rpms.
One last thing is the patriot has a pretty small wheelbase which is better for offroading than the wheelbase on the grand cherokees. I could see getting high centered easier on the basic grands.
Overall I think the FD2 is actually pretty close to the ability level of a basic 4wheel drive wrangler from what I see. I wouldn't compare the fd1 to this though. Its just a step above the crv or rav4 in ability. I would still rate it higher than the Forster though.
#48 · (Edited)
Most of those manual tranny rock crawlers have compound low transfer cases. I would expect competition ones to have low (high numerically) differentials with locking (not limited slip) differentials also.
I bought my 5MT because I knew I wouldn't be doing rock crawling. The low gear in the Patriot 5MT is enough to get a trailer whose weight is within the owner's manual limits moving on level ground. If I were doing rock crawling or pulling a boat out of the water, I would have gotten the CVT for its torque converter.
My trailer tow prep package includes the oil cooler, which ups the towing rating from 1000 to 2000 pounds. I think the oil cooler is a benefit in the six month summertime we have in South Texas, whether I am towing or not.
I'm still not sure if the 5MT was the best choice. The CVT has more discreet controllable ratios than the 5MT. My 2008 Lifetime powertrain warranty does not cover the clutch. It would have covered all of the CVT.
FWIW and YMMV.
#50 ·
the best choice is whatever you enjoy the most... I refuse to buy auto's simply because they bore me.
#57 ·
Yeah, I agree turning the ESP off does make a difference, then other times it seems like not as much.
I wish I could take a day just to play with that aspect of it and try to figure out if there is a solid pattern. But then I suppose just when I think I've figured it out the adaptives will start changing the rules. D@mn computer games....
#62 ·
Question
I have a 2008 jeep patriot FD1. i want to go off-roading with my friends but i am not quite sure of the max that my jeep can handle. i have off-road tires, and skid plates, but other that that the thing is stock. could someone please tell the most aggressive thing i could try. my friends have 2014 Tacoma's with no 4X4. any help will be appreciated.
#63 ·
A lot of that depends on many factors, such as your skill level, terrain types, how brave you are, and how willing you are to risk body damage.
Most trails are rated on either a 1-5 or a 1-10 scale. a stock patriot 4x4 on a 1-5 scale would easily be able to do a 1-1.5 maybe a 2 if you are braver. on a 1-10, I would say 1-3.5.
The big problems you face are articulation, and power. There have been times where I simply couldn't power up a hill, or ended up with 2 wheels in the air due to the independent suspension. and in both instances I could overcome them with some additional forward momentum with a run up to the troubled location, but this gives an increase chance of body damage.
Your best bet is to find a local jeep club website, or group, or a trail guide book, Take the easiest trails, find out what works and what doesn't. Never go alone, and have a place to be hooked to to pull you out of a sticky situation. as you build more confidence and knowledge, you will be able to tackle more trails. You can see some of the stuff I've done at my youtube channel, www.youtube.com/jeeppatriotchannel
