Hello!
On the driver side, I just changed the lower control arm with ball joint, wheel bearing knuckle, sway bar, and outer tie rod. Really improved the steering. However now the steering wheel sits lower on the right side. Drives perfect, but hat the crooked steering wheel.
Youtube, I saw a number of easy videos of how to adjust the drag link on other jeep models, but nothing about the drag link on the Patriot. On those jeeps just loosen two bolts with a 15mm socket, rotate the shaft until steering wheel is straight, then tighten the bolts. Sure looks easy, but found nothing about the Patriot.
If you know, please let me know!
Thank you
Stephen
Thank you
Stephen
