Speaker Reco for 2013 Patriot/Latitude
7.9K views 25 replies 12 participants last post by  laxheromaddness
I want to replace the front/back door speakers that came with my 2013 Patriot/Latitude. I did not purchase the Boston Acoustic Premium sound system so I just have the base system.
I was interested in the Rockford Fosgate but when I plug in my variables on Amazon and/or Crutchfield it says it will not fit my car. Can anyone help? I'm also getting conflicting info as to the speaker size I need...some say 6 x 9 and others 6 x 5. :confused:
Was also considering Kickers, but consensus seems to favor Rockford.
Thanks!
Yes, the 1693 and 1694 RF Prime's do fit the front and rear doors. 1693's are no longer made( but still available ). Crutchfield is no longer carrying the 1694's for some reason.
This is my speaker thread. I have Premium Sound but it would still help out some.
http://www.jeeppatriot.com/forum/showthread.php?t=118689
These instructions are great NHPatriot.
I found the Rockford Fosgate Power T1693 speakers at another vendor called Sonic Electronix. They don't offer nice instructions and adapters like Crutchfield but Crutchfield doesn't carry these speakers anymore. Do I need to purchase separate adapters so they fit? And if so, any idea which?
All I can say is watch your depth, i dont know what it is on the pat but crutchfield can probably tell you. Some speakers now a days have huge magnets. My yota had a problem I had cut a spacer out of plywood. Luckly it fit behind the door panel. In my old chevy had to cut the grills of the panels so i had enough depth.
eBay my friend. I've had all sorts of door speakers. And whoever said they all fit is true to an extent. Not all of them are drop ins. Those rockfords are for sure. If you don't want to buy/can't find the adapters, that's not a problem. Just cut the factory harness and strip the wires. I have the diagram info for polarity. The depth really isn't an issue unless you're doing the rear doors and you have manual windows. The cable is literally JUST behind the speaker location, so a big enough motor (magnet) WILL rub this cable. The front doors need some trimming of plastic just behind the doors if you get a speaker with a wider basket design.
#12 · (Edited)
I just put some Alpine type-r in mine. Very happy with them, small magnet and made of a composite so very light. Fit in the patriot with plenty of room to spare.
ALPINE SPR-69
[ame]http://www.amazon.com/ALPINE-SPR-69-2-WAY-COAXIAL-SPEAKERS/dp/B004WWNSMO/ref=sr_1_8?ie=UTF8&qid=1368898157&sr=8-8&keywords=alpine+type+r[/ame]
Nice bass and treble, I'm only powering them with a JVC head unit and the volume is more than adequate but, they can handle much more power if I ever wanted to add an amp.
Well the speakers aren't making the power, the radio is. So if you're sticking with basic 4-ohm speakers, nothing is changing as far as power goes. If you were to get 2-ohm speakers, you could probably gain a little extra power but nothing significantly noticeable. The biggest difference from stock to aftermarket is a greater frequency response and having a dedicated driver(s) to reproduce a given frequency range. If an aftermarket source unit interests you, go for it. Having a "ghetto" window shattering sub-stage has nothing to do with it. It's nice to have options for better sound processing, imaging, headroom for amplifier upgrades or even just simple Bluetooth, video playback and/or navigation. The limit is your wallet and patience.
#17 · (Edited)
To make it factory you need the entire premium sound tailgate trim and speaker housing parts( not to mention wiring it ). It is different than the regular tailgate trim. Unless you can find it used you are looking at a LOT of money to buy the pieces new. You could try and flush mount some speakers in your current tailgate trim but you would have to make sure before cutting the holes that you have the room in behind you need so measure twice and cut once.
If you want to add the factory parts then these pieces are needed( prices shown are list for gray - beige is a little cheaper )...
1 - Tailgate trim panel = $152
2 - Outer speaker housing panel = $194
3 - Inner speaker housing panel = $189
4 - Speaker housing w/ grilles = $187
5 - Speaker housing handle = $37.45
6 - Speaker housing hinge = $43.20
Note - there are also screws, clips, etc... that will be needed as well as the speakers. As mentioned you will have to run wiring back to them as well.
Parts breakdown...
You all are looking at this the wrong way... for pure audio bliss, you need to put some adaptors in the front doors to convert to a 6.5" round and put some component speakers in there and mount the tweeters on the little plastic piece up front. Run those and some 6X9's in the rear doors to a 5 Channel amp. The 5 channel may be a bit pricier but it allows you to expand later and get a subwoofer if you want. I can send pics of my install. I used all polk audio including an 8 inch where the factory one goes.
Great input. I used to be really into car audio and even after having the Patriot for 4 years I still look at those square tweeter covers and dream about the possibilities lol. My main issue is that I value my trunk space too much and while I like some bass I really don't need two 12' back there. But the set up you are describing with a tube style 8" little kicker in the back would be sweet, Enough to wow with some clear sound and some thump
