Any guinea pigs out there? :nerd:
2in Suspension Lift Kit for Jeep Patriot / Compass [66500] | Rough Country Suspension Systems®
Just looked through the install instructions; kind of interesting.Any guinea pigs out there?
The custom rear control arms are an interesting design, but if they get damaged I wonder how long it would be to get a replacement since there is only one source. And if the company goes out of business or for some reason stops making them are you S.O.L.?..anyone see any negatives?
No, it probably won't. Reason being that the front spacer is only 1" and won't take the drivers side inner CV joint past 23 degrees, which is where it starts to bind and causes vibrations.Hmmmmm... Very interesting indeed. I wonder if this is will cause the same driveline vibrations I had with the RRO lift kit
Can't tell from their literature, probably around an inch, maybe a little more.Kind of a related question: How big is the Performex lift spacer and does it cause the same issues as the RRO lift?
