Ok, as i said in another post i was farming out the rear upper n lower control arms and trailing arm bushings.
Will my guy won't do the trailing arm bushing w/o the rear toe link which after seeing the connection i understand (its easier to lower the arm) me if I wasn't 70y.o. with a currect head injury from cycling I jack up yhe rear end,
Then take another bottle jack under the rear wheel hubs jack that up n un bolt the trailing arms to lower it more i get a short 2x4 n use it as leverage then press out and press in (they show that on you tube) point is trailing arm bushings NOT DONE/
Got the toe link links coming...
RIICR,
Sandstone, thank you
