From
http://www.jeep.com/en/4x4/how_systems_work/freedom_drive_2/
"The electronic control module processes signals from the wheel speed sensors and the accelerator pedal to determine how much torque to transfer to the rear wheels, then sends an electrical current to the ECC that is proportional to the amount of torque required."
If you listen to the audio on that page, it clearly explains that torque gets transferred to the rear axle under hard acceleration or tight turns.
The web page indicates that 50% of torque is directed to the rear axle in 4wd lock mode, but does not address front/rear torque distribution in automatic mode. I also can't find any discussion of torque distribution in the 2008 manual.
The 2008 Patriot manual (pp 130-132) implies than any vehicle with ESP has TCS. The explanation of TCS (p 130) does not suggest that the BLD function is absent in any transaxle version.
Under "ESP 2WD Operating Modes" (pp 135-136), the manual states: "When in “Partial Off” mode, the TCS portion of ESP, except for the “limited slip” feature described in the TCS section, has been disabled," which I take as an indication that all vehicles with ESP are also equipped with TCS. Also, under "ESP 4WD Operating Modes: "all 4WD equipped vehicles can also choose [ESP Off]" and "In this mode, ESP and TCS, except for the 'limited slip' feature described in the TCS section, are turned off until the vehicle reaches a speed of 35 mph (56 km/h). At 35 mph (56 km/h) the normal ESP stability function returns with the exception of engine power reduction. TCS remains off. When the vehicle speed drops below 30 mph (48 km/h) the ESP system shuts off."
The description of FDII (p 244) states that "Off-road Brake Traction Control" is an additional feature of FDII. On page 245, it states "Off-Road Brake Traction Control – When conditions warrant, the vehicle braking system transfers torque from side to side. It does not control throttle input
unlike normal traction control which is active in normal drive mode" [emphasis added]. This is pretty vague, but sounds exactly like regular TCS with ESP partially off. On my current CVT2L, when 4wd lock is engaged and the gear selector is in L or R, the ESP indicator is lit solid (indicating ESP in partial off mode). AFAIK, the sources don't discuss any other modifications to FDII TCS that would constitute optimizations for off-road use. There may well be algorithmic differences, or "Off-road TCS" might just be marketing-speak for "'Off road mode' automatically switches ESP partially off".
