Mine came on at exactly 2500. I knew I had beed in very cold weather, very wet(snoy) weather, short dives (5 miles to work) and extenedd idle times (wife likes to "run" in for a few items and leaves me with the young'n for 30 minutes) I had no problems with the change as I know I abuse the engine. The dealership did not reset the light so I did it right there in the service bay. Took two attempts. Make sure to turn the key to on, and fully press and depress the pedal three times, take your time as ten secs is a long time. then turn it off. The first time I didn't fully realease the pedal, Second time worked like a charm.
