A few weeks ago I picked up a Class III hitch for my Patriot. When I looked at how it was going to fit, I realized that my Dynomax cat back exhaust (4x4 version modified to fit a 4x2) was going to be too close for comfort.
The tiny gears in my head started to turn… time for a new exhaust setup!
I came up with some simple design specs:
• Reasonably Quiet
• No interior resonance/drone
• No loss of ground clearance
I had been toying with the idea of doing a side pipe, or dumped exhaust for quite some time. After a lot of thinking I decided to keep the front half of the factory mid pipe in order to retain the factory resonator and exhaust hanger. I cut the factory exhaust about halfway down the straight section after the first bend after the resonator.
The spot that I cut allowed me to test a couple of different types of mufflers. Initially I thought a glass pack along with the factory resonator would do the trick. I tried a long (24” I think?) Cherry Bomb and a slightly shorter Magnaflow glass pack but wasn’t happy with how either sounded or fit. Both would have required an additional hanger as well as other changes to fit nicely.
While swapping out the glass packs I decided to test out the factory resonator by itself. To my surprise it wasn’t as loud as I would have expected at idle but on the test drive I decided it was a bit too loud. The resonance/drone on the highway was pretty bad.
There was a significant drop in low end torque due to a lack of back pressure with this setup. My taller tires make for pretty low RPM cruising on the highway which made the lack of torque even more noticeable. In cruise control at highway speeds my Patriot would bog pretty hard and lose speed when I hit my test hill. Not good.
uke:
My gut told me I was on to something though so I kept plugging along. I installed a turndown after the resonator which sounded good with a deep low sound for a 4 banger. The turndown also quieted things down slightly and eliminated most of the resonance. The turndown didn’t help the lack of torque though.
I knew I was close so I decided to sit on it for a couple days. I kept thinking about a Suzuki Marauder I had a few years back. It had Vance & Hynes exhaust that I had cut down. It was wickedly loud and lacked torque so I installed exhaust baffles which worked great.
A baffle sounded like a good idea, but the way that I cut the factory pipe wouldn’t allow for the installation of a long straight baffle. So today I decided to give it another shot and went to the parts store. This is what I walked out with:
My idea was that I could use an adapter to step down the size of the exhaust to help build more backpressure, kind of like a baffle. I inserted the adapter (tight fit) inside of the chrome turndown so that it looked like this from the outlet side:
And this from the inlet side:
And then just slid (even tighter fit) the assembly over the end of the chopped mid pipe so it looks like this:
Once installed it looks like this:
I also bought and installed a new exhaust hanger (part #62-00911 from AutoZone) as it is heavier duty than the stock unit and holds the exhaust up a tad higher. All three parts were ~$20 with tax.
Once mounted up underneath the Jeep, my initial thought was that this is an awesome setup from a ground clearance perspective. The end of the turn down is just about parallel with the bottom of the unibody frame rail.
When I started it up I immediately noticed less sound that the turndown setup without the baffle. It has a pretty decent deep sounding tone at idle.
Here’s a video of a start up with a couple revs:
(You NEED A SUBWOOFER for this video to accurately represent what this setup sounds like in person)
If you compare it to my factory vs. Dynomax exhaust video you’ll notice the new setup is louder but has a much deeper tone. Frankly, the new setup sounds less “farty” in person although the Dynomax wasn't horrible:
So being happy with the fitment and sound I took it out for a drive. I noticed right away the “baffle” helps keep the noise down a decent amount. The baffle accomplished it’s job of increasing torque back up to the point where part throttle response is good and I don’t lose speed in cruise control on the same hill. :smiley_thumbs_up:
I’m pretty happy with this setup, and barring any negative long term side effects plan on leaving it be, and installing my hitch.
The summary -
Benefits of this setup:
Negatives of this setup:
• Reasonably Quiet
The summary -
- Easy
- Cheap
- Deep tone
- Lightweight
- Not too loud
- Retains low end Torque
- Excellent Ground Clearance
- Easily converted back to stock
- Burbles between 3.2k-2k RPMs on deceleration (I like this, others might not)
- Might be illegal because it doesn’t exit out the side of the vehicle?
- Makes a sputtery sound when overloaded at very low RPMS
- Might kick up extra dust on trails at WOT
- Too loud for conservative minded folks
- Still sounds like a 4 banger
