Leaking CVT
8.8K views 17 replies 7 participants last post by  Steve53
Anyone ever have the female threads stripped that hold the CVT transmission pan? I had the dealer do a fluid drain and fill about a year and a half ago and have put about 30k miles on the car since then. Just a month ago I noticed some leaky transmission coming from the pan. I decided to tighten the bolts with a tiny 1/4 drive wrench and socket and noticed 3 bolts spinning freely and not tightening, low and behold, the threads were stripped. I had a shop put longer bolts in for me, RTV around the gasket and re-fill with new fluid. It was still leaking after that, they ended up dropping the pan again, extensively clean the mating surfaces, and re-RTV the gasket and bolt it back up. I'm gonna give it a few days to see if it leaks again.
Has anyone had this issue with the threads stripping? has anyone had the bolts drilled out and retapped with larger bolts? I wonder if the immense heat that the CVT can generate caused the aluminum threads to become really brittle over thousands of heat cycles.
Like EW said the metal is very soft and can strip easily. I haven't had one strip yet, but I've seen a couple of people here who have.
If it still leaks, you may need to check the pan to make sure it's not warped due to being over tightened.
If it's warped, the best thing may be to replace it with a new one, and get a good gasket, not one of those flimsy rubber ones.
The last one I put on was a Fel-Pro and it's leak free.
Thats one way or scan guage that tells trans temp. Scan gauge plugs into obd port under dash and can show engine temp trans temp voltage and others. You have to have accurate trans temp readings in order to match chart that comes with aftermarket dipstick. You are not getting correct readings from what you have been doing.
Yes, Torque on my phone does show trans temp. I have a bluetooth ELM327 reader. However, I also have Torque installed on my Android head unit, and that does not show trans temp. Maybe it's device dependant?
UPDATE So after going to a car shop they tried putting longer bolts in since the female thread leangth is longer than the bolts themselves. They also placed a bead of RTV all the way around the gasket and they re-filled the trans fluid but it kept leaking days after. I took it back and they extensively cleaned everything and re-filled again, it was still leaking.
I now have it at a transmission specialist shop and they are properly retapping the female threads and re-filling the tranny again :( i'll update if the leak finally stops
If there is enough wall around the stripped holes, have them install helicoils (new thread inserts). You drill the stripped holes to the tap size of the outside threads of the helicoil. Then tap thread the holes and screw in the helicoils. The inside diameter of the helicoils are threaded to your original screw/bolt size. The end result is threaded holes that will use the same thread as the original bolts did. You can propably use the old bolts as long as the threads are good and not full of aluminum.
