I bought my 2009 Patriot new in November 2008 and have never been so displeased with a vehicle. I got the Lifetime engine, power train warranty but I doubt the rest of the patriot will last long enough to use this warranty. I baby this Jeep and it has never been driven hard and has 127,000 miles.
Heres what has worn out...
At about 50,000miles the hazard warning switch quit working. At the same time, the ESP switch quit working.
In 2011, At 87,000 miles the lower control arms and several front end suspension parts had to be replaced at over $950.
When having the cooling system flushed in 2012, the dealer tells me he sees rust under the alternator, $570+ to replace. Went to a local shop and got a rebuilt alt for $280.
Cooper Replacement Tires worn out after being on only 47,000 miles. I rotate the tires every 5-6k.
Last week, May of 2013, the auto shifter will not go out of gear. Took to repair shop thinking it was the brake light switch. They put the switch in and it did not help. They thought it was the trans control module and said dealer would need to fix. No charge.
Took to dealer, they said switch was bad. $155.00 after new switch did not fix shifter prob, and 7 hours waiting later dealer says it may be the TIPM. But will not promise that is it. May be other modules bad too. No better off than before it went in. TIPM replacement repair, $780! I told them I did not have that much to put in it. So now every time I need to shift out of park, I have to push the white release lever on side of shifter console and the check engine light stays on. how long can it run using the release lever all the time? Also a clunk has developed in the rear end now. What else will go wrong?
When on a hill it starts out like it is in 3rd gear, very bogged down. Gas consumption has never been good but now it seems like it is guzzling gas.20mpg. Would the TIPM have anything to do with gas mileage?
I have a work bud who owns a 1993 Honda accord with over 375,000 miles. No major problems ever. Still has the original a/c compressor but did replace the alternator about a month ago.
I wanted to buy American so got the Patriot. Now I wish I had gone with Nissan, or Toyota, or Honda. I am considering trading this thing off before something else goes bad but will take a huge hit selling it with the repairs it needs. I feel like any money put in it now is throwing good money after bad.
If you are considering buying either a new or used Patriot. DON'T DO IT! Avoid this vehicle at all costs new or used. I feel like a used Yugo would even be less trouble.
