This is a huge issue on the Wrangler forums. I have been lurking a bit over there. Read this:
http://www.wranglerforum.com/f33/the-importance-of-changing-out-stock-bolts-128154.html
and this:
http://www.wranglerforum.com/f33/di...m/f33/diagnosing-death-wobble-and-fixing-non-dw-shimmies-and-wobbles-78034.html
I am shocked by these reports from owners. For those that may not want to read through the details-
Supposedly the Wranglers have several bolts holding the suspension together that are actually the WRONG size! Someone posted a video on the forum showing the amount of play due to the bolt,. It is also apparent that the longer you go without swapping the bolts for a proper fit and bolt type, the wear on the inner threads are further damaged and can cause this to worsen
I have noted that many of those that have experienced the DW have had a lift, but not all of them. I think Wranglers have THE BEST aftermarket support of any vehicle produced, I cannot imagine blaming this on aftermarket suppliers is fair. If this was very isolated, then yes, saying improperly maintained after market suspension parts play a role is fine. But not all these owners are negligent in their vehicle care.
I am sure some of the older members remember the times when solid axle vehicles would skip and skid a bit on hard turns, Mustangs, Camaros, etc. But its a non issue with modern vehicles. Perhaps the Wranglers design with a high center of gravity and short wheelbase plays a role as well. But if you read the posts about the non-shouldered incorrectly sized bolts, your head may explode!
I am no engineer, I do not have a great grasp on design and hardware, but the way they explained this on wrangler-forum is pretty easy to understand-
Jeep used the wrong bolts and they used the wrong type of bolt. INSANE!
